- Jul 15, 2013
- 7,499
Scroll down searching for best price by clicking above website.
Thanks! I'm not sure if I got it right. The url is to Google search… None of the Google suggestions are to part supplier for Kubota gasoline engines :-( I think I somehow get different search results....
partlimit.com
Good tip, great work - thank you very much.Looking at your pictures and doing the little research thats available to me, I might have figured something out. First, that coil looked like it might be the same as a Kawasaki coil. Kubota may be using the same coil?? Then I went to an image research and found what looks like the same coil listing that it is for a Kubota and Kawasaki engine. I don’t know if any of this research is worth any more than the time it took, but if you have a Kawasaki dealership or repair shop in your area, it might be worth your time to talk to them and see if they would by some chance they would have one in stock. You will notice that the attached website lists both a Kubota and Kawasaki part number, which might help you in your search. I’m assuming that these coils use an internal triggering chip, so resistance measurements will do you no good. Sorry I can’t be of more help. Luck luck and let us know if you have any success.
PARTSRUN Performance Ignition Coil Replaces Kubota Coil Igniter 12182-67060 AE6500-3Y-USA ARX5500-B-3Y FIT for Kawasaki 21121-2086 AM121820,ZF704
PARTSRUN New High Performance Ignition Coil Replaces Kubota Coil Igniter 12182-67060 AE6500-3Y-USA ARX5500-B-3Y FIT FOR KAWASAKI 21121-2086 AM121820,ZF704partlimit.com
Yes, good advice. I did that but not really helping.Try contacting Kubota Europe.
Kubota GH250-Q-1-SO-UK2 (No decode for the UK2 so it probably means its was especially built for the UK market.)
don't forget about the I think is a 0.25 air gap between the coil & magnet on flywheelYes I did (I learned that from YouTube).
My next step is to remove the whole Kubota engine, test it well, remove the flywheel... So far it looks that no spark, and I have not found any reason. I'll try to measure the coil AND order already a new one from somwhere.
BTW - the engine worked great. One morning, it just did not start. I had disconnected and reconnected the battery previous evening, maybe that is some reason for something?
Fuel and everything else okay.
