i need help
krisandchristina
i have a 200 series ransomes zero turn mowes 22hp kohler ran friday til dark tried to start it saturday it wont do anything when you turn the key over it makes a single tick under the carb
KennyV
WELCOME to LMF...
Is the PTO off, and the controls in neutral ... :smile:KennyV
krisandchristina
thanks for the reply i figured it out it is the ignition switch temp fix with wd40
benski
You won't want WD40 in that switch for long:eek:. It will gum up and attract dirt. Some classic lock-ease (graphite base) is more appropriate.:biggrin:
KennyV
benski is Right about WD40... that stuff is not good for much, it is an okay starter fluid, but a terrible lubricant and a marginal cleaner...
I can only guess why so many people buy it... :smile:KennyV
