I hit a rock...
Tikal
While mowing my friend hit a rock and it bent the the thing that spins, is there a way to replace that??? I tried hammering it to unbend it but failed to do so.
Sent from my iPhone using LMF
BKBrown
If a rock was hit hard enough to bend the blade there is probably a shear pin/key that will need changing too.
There will need to be more information about the mower - Make, Model, Engine --
everything that will identify exactly what mower and engine is invloved.
Tikal
The shaft bent too, here is the info you requested;)
Thanks!!
Model number: 917. 388562
Serial number: 042204M 010107
Briggs and Stratton engine.
BKBrown
If the shaft is bent --- It will need some serious engine work - If you or your friend are good at engine work, fine, if not you may be looking at $ for repair or a new mower.
You might get better advice here -- Good Luck !
Tikal
Is the shaft the thing that comes right from the flywheel?
BKBrown
I'm not familiar with that model number - sounds like a push mower with the blade attached directly to the shaft. If that is the case, the shaft goes directly into the engine and will need to be replaced.
Tikal
The blade is not directly attached to the shaft, I took it of already:D
Is there a way to change the shaft? I have another craftsman I can use for parts.
KennyV
Is this not a rear bag, 21 cut 4.5 hp push lawnmower... ?
If the blade was not attached to the crank shaft... what was it attached to?
:smile:KennyV
Tikal
:smile:KennyV
No, I was saying the blade is attached to the crank shaft but it comes off of the crank shaft.
Is there a way to change the crank shaft?
BKBrown
It is possible to change the shaft, but the engine will need to be taken apart and put back together.
