Woo hoo! I just took delivery of a brand spanking new Bob-cat Fastcat Pro ZT Thursday and decided to do something I've never done before in my life - read the owners manuals (mower and engine) cover to cover before using it.
Now I know why I've never done this before. They swamp you with so much safety garbage for liability purposes that you can't hardly find the good stuff. If that's not bad enough, there is always the conflicting advice, the mower manual says to do the first oil change at 8 hrs while the engine manual says to do it after the first 5 hrs.
Then there is the just plain silly stuff. The Kawasaki manual that covers three of their FX engines says to remove the sparks plugs when winterizing and put oil in the spark plug holes. It then provides a picture of the engine with the plug removed and an arrow with the label "Spark Plug Hole". Lol, I'm pretty sure that most people can find the spark plug hole after they've removed the spark plug.
Anyway, i know these types of things are common to all manuals for things with motors or engines, but after reading them cover to cover, it really got to me this time, ha ha.
By the way, this Bob-cat is the beast!!!
Djdicetn, what the reason for not changing the filter with the oil every time. I always was told oil and filter at every oil change, car truck lawnmower or what ever you have?
Bakerg - yah, I've got to get a picture posted before I get it dirty.
Djdicetin - I'm not sure how I'm going to do the oil and filter thing. It just seems so counter intuitive not to change the filter with the oil but I would assume that the boys at Kawasaki know what they're doing. One thing about this mower that I absolutely love is the oil drain tube that is clamped to the side of the engine housing. All you have to do is pull the yellow cap off the yellow valve, twist the yellow valve a turn or so, and drop it down into the collection pan - easy peasy. The hose and clamp are very sturdy so it should hold up well.
Anyway, back to the frustration with the owners manual. In the storage section (the page before the spark plug hole picture), it says to close the fuel valve and remove the sediment bowl. It would really like some help on identifying these two parts. Are they talking about the fuel shut off valve going from the gas tank to the carb or a fuel valve in the carb itself. And just where is the sediment bowl. I think it's the round thingy at the bottom of the carb also housing the float but if that is it, those two screws are going to be tough to reach. How 'bout a picture of that Kawasaki instead of a picture of a "spark plug hole"?
At least my Honda doesn't get dirty :wink: (see picture).
<img src="http://www.lawnmowerforum.com/attachment.php?attachmentid=14429"/>
Now that's what a working mans mower should look like.
My mowers see water it's called rain if I did not cut in the rain I would not have any yards to cut. When I get a email that's says that 50 yards are due in 4 days they mean 4 days. In march I was cutting while it was snowing. The rain does slow us down missed my mark this week by 3 yards that I will do tomorrow in the rain because all it does here is rain
(( racing is the only sport that you need two balls ))
Seriously, when you have to mow in the rain do you have to spend some time cleaning up the machine(s) before storing them??? Storing them all wet can't be good.....right???
Yes, there is usually more grass to clean out from under the deck along with grass/dirt stuck to every part of the mower imaginable that you have to wipe clean. I try to dry my mower off, but I don't know if it would hurt anything if I didn't. It will dry in the garage and it's not like it is just sitting in the rain for days and rusting.
Sounds like that Cub doesn't stand still long enough for rust to form:0)Mine stays on the trailer in the driveway.
I use it in the rain it can sit out in the rain.
I have had this cub for five weeks now and my 150 hour warranty is gone on my 3rd set of blades. Do I worry that this mower will rust?
No not at all.
For a $1200 mower this is a good mower I work it very hard.
It's like the people that drive there car in the rain and snow then park it in the garage to keep it out of the weather. Smh. A mower is made to use out side so why not leave it out side.
Just now went out and looked under my deck and no grass stuck under there
