I am really bad at this....
Phogan
Also no action when I put some starter in the carb.
Phogan
Fish
Pull that wire off of the bottom of the coil in pic one, and try again, and pour a bunch of fuel down the carb, see what happens.
What is this on, from the one pic, it looks like it has electric start, put up all of the engine's and the mower's model numbers..
reynoldston
No spark.
Now what?
Phogan
After cleaning up all the rust and still no spark. You should have two wires to the coil, large spark plug wire called secondary wire and a small wire called primary wire. disconnect the small or primary wire and then see if you get spark. If yes you have chassis wiring or switch problems and if no get the coil tested because you may have a bad coil. Once you get spark and if it still doesn't run then work on the fuel. Do only one thing at a time so you don't get over your head.
Phogan
It's a Briggs & Stratton 900 intek series 9.0 horizontal on a DR leaf vac.
Phogan
Hot dang! I un-hooked the little wire with the white connector and I have a spark!
Next??
Thanks so much!
Phogan
Fish
Wow!! Try to get it to start then!!!! You may have to yank the plug wire to shut it off, but you will have narrowed your problem
down to fixing it!!!!
Fish
Give it a shot of carb cleaner or gas!!!!
Phogan
It started!!!!
Thank you so much!
Remind me again what wire I un-hooked?
Phogan
Fish
The "kill" wire, we need more info to help you more...
