I guess you mean me. When talking about hydrostatic drives, I assume you mean drives or units which include a variable pressure pump, some sort of controlled pressure pistons, a relief valve system, a fluid which is used to transfer the energy and hoses connecting this unit to one or more hydraulic motors and/or cylinders, depending on the size, to do work. The pressure pump is powered is powered by either an electric motor or fuel driven engine. Today's tractors, as well as many other pieces of equipment can now use this type of propulsion system, because the technology is available to put all these parts into a unit just a little larger than the old 6-speed geared transmission. In my opinion, that is the reason it can be called a hydrostatic transmission or trans axle. It has all the components, except hoses, of what you are talking about. Some company's (Simplicity, Wheel Horse, etc) even run their power steering and PTO cylinders off the same pump with hoss. Both the same in different size packages.
