Just bought an old HA4045 yardman. Push pedal either way and it goes nowhere. Previous owner says it was all running last year but he says if I take it back he will check it out. It means Ihave to borrow a trailer to do so. Is it something simple that I am not doing. I have fiddled with the springy thing at the back which allows you to neutralise the hydro and in either position it does not drive. What does the black flap/switch/ leverunder the dash do because it is loose and seems disconnected. Where would I get an ops manual.
