Hydro Transaxle gets a bit slow when it warms up
Skippydiesel
John Deere Sabre with Kholer 17.5 hp engine.
This mower must be at least 30 years old. Owner says he purchased it, about 30 years ago, second hand, from a mower repair shop and that they put a brand new engine in it at that time.
The mower initially starts runs well and appears to be fully functional BUT as the work time passes, the mower gets slower & slower - reverse will hardy work at all.
I have told the owner that it is likly to be uneconomical to repair, however he wants me to have ago.
I could not find a model/serial number.
At this stage I am planning to remove the transaxle, drain the oil and replace it with new. Please advise grade of oil (I am in Australia so brands unlikly to help much).
FYI: I have 4 litres of a 25W70 mineral oil, on the shelf
Tiger Small Engine
The labor will be as much as the mower is worth to remove transaxle, drain, replace oil, and replace transaxle. Consider using an extractor to get most of the oil out versus removing. Common oil to use is 20W-50 synthetic, however, you need to find out for your specific application.
Hydros are the only place that I use full synthetic
The trans is good for about 1000 hours , a bit more if the owner was careful, never ran at 1/2 engine speed and did not tow.
There is a tech who advertises on ebay , I have used him several times
HE machines the kidney plate and the cylinder blocks back to flat again and at the correct surface roughness then shims them to the right clearances .
Fills it with oil & send it back purged & ready to instal for $ 400 AUS .
Now if he has to add parts the price will go up but the drop in pump/motor units are $ 600 to $ 1000 wholesale ( if you can get one )
I have used him a couple of times and now will not open a box for love nor money.
Tell him you are a tech and ask politely for a 12 month warranty ( normal is 3 ) .
I usually get new seals put in at the same time ( all 3 of them ) .
I charge the customer 2 hours labour + 2 x freight and it still works out cheaper than just buying the parts .
Cheap & nasty test for hydros
I use a tilt trailer and a good hydro will pull in gear engine off with strong resistance & stop when I stop pulling
A shot hydro will take off like Mulga Bill's bicycle the second the brake is released
Test is done with engine off .
The tranny man uses a mower shop in Eagle Vale ( Sydney ) for drop off & pick ups
Depending upon how bad the wear is heavier oil can add another single season to 5 years .
That Sabre/Scotts mower will have a Tuff Torq K46V (or K40 depending if it had been replaced). They are not that hard to remove for draining the oil. Now if the oil comes milky then the seals need to looked at and internal filter change needed as water is present.
As for cost of the tech time it is the customer option if he wants for the tech to do an oil change. Some old mower have been very well taken care of is worth the time spent on them, others that are abused are not. I just got through last month repairing a Scotts S17.5 last month that look like a nearly new mower.
And Bert some the Tuff Torq K46 transaxles will present good resistance pushed backwards but no where the same when pushed forward yet nothing is wrong with them.
Skippydiesel
Thanks you for your informative replies -
This mower has not been well maintained.
The owner wants a quick/cheap fix.
I have suggested replacing the oil - he has agreed.
Will any 20-W 50 full synthetic engine oil do the job or should I be looking at something more specific?
Skippydiesel
Have removed transaxle (Tuff Torq K46 V) from mower & drained some really black horrible oil from it.
Cooling fan down to 2 blades - won't be doing much to keep the system cool.
The whole thing covered in compacted chaff/mud mixture - more heat retention.
Surprisingly, the magnet had only a little "fuzz" on it.
Refilled with 2 Litres, full synthetic, Penrite HPR 10 10W-50 motor oil. This is about the cheapest job I can do for the owner, any more and the cost (already more than the mower is worth) will become downright embarrassing.
In its day the JD Sabre must have been a quality ride-on - that its lasted this long, with so little care, speaks volumes.
Craftsman Garage
I am getting ready to dig into my old TT K46 from 2004. Funny enough, It is the exact same symptoms: drives good until warm and sluggish up little hills. Replaced fluid and Didn't do crap. On YouTube, Taryl fixes all has a video about fixing a tranny with similar issues. I am going to replace the filter and resurface the pump as he says. His fix worked great on the John Deere he fixed with the K46, so I will be trying that and you probably should too.
Skippydiesel
Thanks Craftsman but no.
The list of defects on this ride-on would cost the owner thousands, for me to repair.
Different story If I owned/was given the old girl, then my labour is not factored in.
Got her going this afternoon - seemed to move forward/back okay - don't know what the story will be, when she's been in work for 30 minutes ++ - I am sure the owner will let me know.
It should do better since the oil was burnt. But you at least replace that bad fan and clean the exterior of the unit. They are around $10.
The fans are not expensive just check that you order the right one as they come in push or pull blade angles
Without the fan the oil will overheat get too thin and loose traction.
An essential job with every service is to thoroughly clean the transmission
I use a very long air duster bought from Cheap & nasty car parts almost a decade ago
Do not use water as it just sets the dust into concrete .
