Well. weeks later it's almost there. work, taxes, family. and more work. So. does anyone have any good pictures of the front and back control panel connections as it relates to the governor arm, spring, shaft, and throttle linkage. I feel like something isn't right. I set it per the manual which states:
Turn the top end of the governor arm counterclockwise to fully open the carburetor [G] throttle valve and hold it there.
Turn the governor shaft counterclockwise fully to the end of its travel.
Tighten the clamp nut.
Which I did, and the arm lines up with the shaft exactly where it did before disassembly, because I do have a picture of that. The linkage is installed correctly as well. I believe the governor spring is, but maybe the arm on the control panel that rotates isn't in the correct orientation or sequence or???
So the problem. When I try to rotate the throttle arm on the control panel it tries to open the throttle more and starts to flex the linkage from the governor arm to the throttle. Maybe I'm confused on how this works. When I manual move the governor arm down (clockwise) the throttle will move down (clockwise), which I assume is closed (clockwise is closed, rotates the throttle toward some kind of stop screw), (counterclockwise is open...per the manual even.... and it rotates the throttle toward a hard stop). At this point I'm scratching my head.
Any pics? thoughts? guidance?
