Hustler Super Z/60" xr-7 Deck, Idler Pulleys
Skippydiesel
My Hustler project has four idler pulleys. Three fixed, one tensioner.
The two front ones feel loose - would like to replace them.
Shaft OD 5/8"
Two front are the same 6 3/4" OD, approximately 3/4 height, 21/32" ID (inner bearing). Both black, flat , assume welded.
One (Good) at the back, same OD, approximate height 31/32", same ID (inner bearing). Silver appearance, riveted, made in Milwaukee.
So far have only been able to find replacements with 11/16" ID. This will be very loose on the 5/8". What to do? Please advise.
Thanks :devilish:
Note: Photo off internet, for illustration
I am fairly certain that is the correct deck IPL. But without the mower model it hard to tell as they might have changed them.
The 781385 [Rotary 10226, Stens 280-838] will be find as it is the stand-offs that fit the pulleys and capped with 1 inch washers. If it weren't for the stand-offs the pulleys would never turn.
The Stens are 1-1/8" height vs the Rotary at 1-1/2" OD 6-3/4" with the flats on both at 6"
Moving idler is 781856 [Rotary 12696, Stens 280-874]. The Stens is 1-3/8 height vs the Rotary at 1-5/16" OD is 5-3/4 with the flats at 5".
ID of all bearings are 11/16".
BTW I have installed 6 of the Stens 280-838 on at least 3 XR-7 decks without since 2020. Two if them have been on the customer's Super Z across the street since 2022.
Hi Rivets,
Thanks for getting back to me.
Page 7-4 7--5
Part Number 781385, 6" Idler Pulley, x 3, appears to be the right part.
I looked up the shaft/bolt PN 783738 x 3, CS .625-11 X 3.00 FULL HX G5 ZN
    • CS: Cap Screw (Hex Bolt)
    • .625: 5/8-inch nominal diameter (0.625 inches) (= 15.88mm The same as my measurement)
    • 11: 11 threads per inch (UNC coarse thread)
    • 3.00: 3.00 inches in length
    • FULL HX: Full thread hex head
      My existing flat idler pulleys measure 6 3/4" OD - the OD of the belt surface may be 6".
  • The ID of the bearing (to fit the 5/8 shaft) needs to be only slightly larger 41/64 -21/32 for a snug fit - all I can find (at this stage ) is 43/64 which is a loos fit.​
  • :devilish:​
Has anyone tried to replace the bearing in one of these Flanged Flat Idler Pulleys ?
Just checked one out - has about 6-8 spot welds holding the two halves' of the pulley together.
Looks like it may be passible to drill out the spot welds, replace the bearing with good, rivet the two halves back together again (+ add more rivets for safety/strength).
If it's possible, a better quality bearing and the lower cost may be an attractive proposition.
1794963418179.png :devilish:
I did a little digging and found this aftermarket pulley listed for some Super Z / X-ONE / ATZ models:
https://www.fridayparts.com/deck-id...-one?queryID=41b48c643eb265bf195cd584db244f82
It shows replacement number 602821, not 781385, and I don't see the OD, height, or bearing ID listed. I wouldn't assume it's right for an XR-7 deck just from the model fit.
If you go that route, it might be worth having the seller confirm those measurements first. Since your manual is pointing to 781385, I'd still lean toward that number or a known cross for it.
Not worth the trouble...
And 602821 is the commercial replacement for the 781385. It is a much better pulley; unless, grass build up on top the deck is a problem. As if this is the case the spokes will fill with grass.
