Hustler Super Z/60" xr-7 Deck, Idler Pulleys
Skippydiesel
My Hustler project has four idler pulleys. Three fixed, one tensioner.
The two front ones feel loose - would like to replace them.
Shaft OD 5/8"
Two front are the same 6 3/4" OD, approximately 3/4 height, 21/32" ID (inner bearing). Both black, flat , assume welded.
One (Good) at the back, same OD, approximate height 31/32", same ID (inner bearing). Silver appearance, riveted, made in Milwaukee.
So far have only been able to find replacements with 11/16" ID. This will be very loose on the 5/8". What to do? Please advise.
Thanks :devilish:
Note: Photo off internet, for illustration
