After about 5 hours on mower (had a lot of mowing to catch up on) I took it back in because the hydro system seemed to make more noise when turning to the right. They checked it out, did not find anything wrong, talked to factory. I was told it sounded OK. I had nothing to compare it too. But, they reminded me of the warranty...
I also told them that the handles were not perfectly even. When I am going straight on flat ground, and push both handles all the way FWD, it will make an easy slow turn. It still does it, so I need to see if this is an adjustment I can do, or normal.
But it has already been a little work horse, and has saved me so much time than what the old lawn tractor could do
