Georgia ZTR
- Aug 1, 2018
- 8
How can you increase the speed of the hydro's? I have changed the Hydro Oil and filters. Tire Pressures are all at 9 PSI. Still clocking at 5.5 Mph (Raptor SD 48" 112 Hours with 2800's Hydros).
Georgia,
Btw, that isn't the official way to speed up your mower's pumps. Bert will most likely jump in to give you a clearer picture on the way to increase pump pressures thru pop-off valve springs in the pumps etc. Hope so, he is the man on those.
The method I gave you is simply to make both wheel motors drive straight to their maximum thru linkage adjustment. PS. That is all the Hustler dealers are going to do for you and to be honest, good luck with that. lol
Max
GeorgiaZTR,
Jack up your mower, with the wheels off, sticks in park, loosen the front nut about a quarter turn, tighten the rear nut about a quarter turn at a time and do that until the hydro pumps begins to creep in park. After you have made the motors creep, back them off a half a turn. Put the wheels back on tightly, lower the unit, run it on "smooth & level" ground to make sure it is tracking straight. Clock it for speed.
Have fun.
Max
