You are kidding right?The raptor SD 54 is a crazy great value for the money... if they gave you the wide-open deck design that they give you on the fast track they would never be able to keep up Manufacturing. Here are some pointers that might help out a lot.. Mow no more than one half your grass height at a time. Mow when dry and at least two and a half inch cut height... it will be healthier for your lawn and will give you a lot more airflow. Sometimes just cutting another quarter-inch to half-inch higher makes an unbelievable difference in load inside the deck. Slow down if you need to. If these tips don't work move up to Gator G5 blades or high lift Hustler blades. $80 Harbor Freight hydraulic lawnmower lift can be a big friend.
I didn't have any of those problems with mine.... a 650 pound machine with big tires.... heavy duty mower deck....decent engine, 2800 series hydros ....good warranty and in my case a good dealer... all for $3,800. I don't know what I could have bought that would have been a better value.
i cut a lot of very tall grass and had constant clogging
you need to get the oregon gator blades, which have more lift and blowing action. i also cut my deck opening to get rid of that corner that holds a lot of grass.
there are threads on here with this info
+1 cut the corner and the clogging goes away. The gator blades also help a lot as well.
And bolts coming loose as a complaint...please, thats the lamest thing Ive heard all day.
We have had at least 3 complaints on this forum for it happening. Lets see we are but a small forum. Probably only see 10% of the world problems. If we have seen 3 then there are a lot more.
3 mowers with a loose bolt and that makes a bad mower...wow. I mean if 3 = 10% then what 100% = 30 that had loose bolts out of how many sold?
Ever had a loose lug nut? Did that make a bad car?
I would think dealer prep has more to do with loose bolts then it being a bad mower.
I knew someone would bring up johndeere
You can not compare a $4000 JD to any other $4000 mower. JD will lose every time.
I used a SD for two weeks I hated it. The deck clogged very easy.
It was not good on hills.
The drives are to weak.
I will stick with my Toro's for less money.
That's kind of funny.... between the economical John Deere Sabre line... and the upscale John Deere's we ran pretty much every other dealer out of town. We serviced a town of 4000 plus a rural area... we sold between 200 and 350 ride on units every year and 50 compact tractors. We did 2 million in lawn and garden sales. But...John Deere knows how to engineer things to make a profit there's no doubt about it.
I'm curious about your constant claims that the 2800 hydros are weak on the raptor SD.... could you tell us more about that experience.?
That's kind of funny.... between the economical John Deere Sabre line... and the upscale John Deere's we ran pretty much every other dealer out of town. We serviced a town of 4000 plus a rural area... we sold between 200 and 350 ride on units every year and 50 compact tractors. We did 2 million in lawn and garden sales. But...John Deere knows how to engineer things to make a profit there's no doubt about it. I'm curious about your constant claims that the 2800 hydros are weak on the raptor SD.... could you tell us more about that experience.?
That's the first thing I thought of even before I bought it, because when I looked at the discharge, I wondered why they didn't leave it completely open. I even questioned the dealer on whether they had any complaints on the discharge clogging, and he said out of the thirty + he sold, he could remember only one that complained. I thought maybe it had something to do with air flow plus I hated the idea of having to take my cutting torch to a brand new mower to make it work. I guess maybe I'll have to cut the deck opening if the dealer doesn't resolve it. I was looking for a mower that would cut the grass with no trouble if for some reason (weather or work) I didn't get it cut when it should have and it got a little tall or thick or was still a little damp. So far, this Hustler is not the answer, and is actually the worse of any brands I've previously used for clogging and grass hanging up underneath the deck. I doubt that the dealer will be able to come up with any answers either, but who knows. Maybe I'll have to try the Gator blades.
The mower slows down to much going up steep hills. I drives whine. A lot of times when turning the side that should be going in reverse will stop moving. I am betting it is not the drives them self but the drive belt set up is letting the belt slip.
And what mower do you have?I never experience these issues on my mower with 2800 drives.
I have a cub with the 2800 drives and they work fine. That's why I said i bet it is the drive belt set up. Many have complained about this.
Raptor SD 54
How big is your yard?
Flat- hills?
I used one for two weeks and was not happy with it at all. The cut quality was poor. Did not stick hills at all.
Put 70 hours on it and the deck belt came off twice.
I find that most people that buy this mower Is the first ztr they have used.
Why would anyone buy a new mower knowing you need to customize it to fit your needs?
Why not just buy a mower that is ready to go?
Really you've never bought something and then 'customized it to fit your needs'....:thumbdown: I.E. bought a house--> painted a room a difference color. Bought a car put new tires on it. List of examples goes on and on. Just to keep the conversation in check, I did not change my blades or cut the deck opening for the first year and half. I used it stock and smiled every time I turned the key :smile:
I have a friend that has a John Deere Lawn tractor down the street. I asked him one day why a JD. He said My grandpa and dad have always bought them so I did too. I asked did you compare it to any other mower. His answer was no.
Lead around by the nose. Sheep mentality. Maybe more like lemmings mentality.
Its the bolts holding the drive motors on.3 mowers with a loose bolt and that makes a bad mower...wow. I mean if 3 = 10% then what 100% = 30 that had loose bolts out of how many sold?
Yes you read it right.Am I reading this correctly? You bought a residential mower and put 35 hours on it a week? Why would you buy a residential mower if you are going to put this many hours on it.
It's all about the money not showing off.
My mowers are 2011 toro SS5000 they cost $3000 new. One will turn 3000 hours next week.
3000 hours
X
A average of $50 per hour
= $150.000
Subtract the cost of the mower plus belts and blades and 4 sets of bearings this mower has still made over $140.000
I run 4 of them full time.
Have never had to replace a drive or a spindle. The decks are still good.
The engines still run like new.
Why spend $10.000 on a mower that cost more to operate. I do not have to buy hydro fluid or filters. Save $200 a month.
Don't have to replace a hydro hose.
I can sell any one of my Toro's today for half of what they cost new.
My $12.000 scag is setting in the back yard with its 3rd bad hydro pump at $650.00 with 1200 hours on it.
Blades my blades cost $38.00 a set not $60.00.
Deck belt $14.95
I put more money in my pocket.
My trimmers and edgers are also toro. You get them free with a mower.
I cut 98 foreclosed homes a week.
My second crew cuts 125 a week
I sub out around 300 a week.
So what I am doing must work.
I guess that all makes sense, I am not a professional mower so I just know I have heard on here many times about the difference between consumer and commercial duty but your experience speaks for it self. Next question, what prompts you to hang out in the Hustler section if you dislike them so much? Seems a little strange but you must be getting something out of it.
Carscw..... didn't those toros come with Kawasaki engines standard equipment? Wow... the kaws made 3000 flawless hours!
Not sure. I will call them and find outSo what is the Kohler Pro equivalent to in the kohler lineup today.... it seems like they have a new engine line every three years.
RhettWS, thanks for your reply. That's what I would like out of my machine. I just want to be able to cut grass if it happens to be a little tough or gets a little longer than normal. I hope we can figure something out, but I'm kind of worried that all the dealer will come up with is that either the grass must be too wet, which it isn't, or I'm going too fast, which I'm not. I don't know, maybe I'm cutting it too short, but like I stated before, I've never had this much trouble with a deck on any other mower, and I'm cutting the same grass the same way. Maybe switching blades would help. My wife was mowing yesterday and had the same trouble when the grass was a little tough, but our neighbor was going along with his 10 year old Simplicity rider with no trouble at all. Later in the day when the grass dried down some, she said it worked fine, but who can, or wants to wait until 5 PM everyday to cut grass????
Even though your thread has gone off track. I hope you get this working for you.
Have you tried high lift blades?
I find that gator blades clog the deck more. They are made to keep the grass under the deck.
Did you put them on backwards? Lol
The gator blade is a mulching blade.
The back wings throw the grass towards the center of the blade so the grass will stay under the deck. And get cut 4 to 5 times. This is the reason the grass cut clumped up under the deck. They are not high lift blades they are mulching blades. The reason they do not clog the shoot up as much as regular blades. Is because they do not discharge the grass as fast or as much.
What drives are in that toro?? 3100??Toro ss5000 $3000
Better cut quality.
Better drives.
Better deck blast threw tall wet grass.
That Toro runs the light ezt Transmissions that Hydro Gear makes. They are self contained with no filters or oil changes... but they do have a pretty good record for staying together as I think carscw can attest.
What drives are in that toro?? 3100?? If so,,$3k is a great deal man,,dont know how they do it...My SD is awesome so far,,i cut crazy sloped lawns and some cow paths,,i just take it real easy over the ruff stuff. It does need better tires,the discharge opening needs too meet my angle grinder,,and other than a few bolts upgraded or spun around the other way,,its been a great machine to me,,hope too keep it for at least 1000 hours..than i will look into that Toro for sure,,a fabbed deck is a must for me though,,I just cant deal with the stamped design..looks so cheesey to me....
Ok yeah,,we had an older JD with a stamped and the deck just seemed to have great suction and flow,,left a really nice cut and stripe...the RSD leaves a scraggler here and there,,especially if the blades are not sharp...all the mowers I had left scragglers though...alot of times it depends on the type of grass also.I like the stamped deck I feel it gives s better cut.
I use the gator blades in the fall and winter.
I don't run them year round because they only last 5 weeks at $60 a set.
My low lift blades last 8 weeks at $38 a set.
I found a place to order them online that ended up at about $31 a set shipped.
Link?
I was getting them off ebay for just under 50 shipped.
The RSD 54 does leave a pretty good windrow when the grass is high and damp,,I find I most always have to double cut to make it look really nice..like I said,,that opening is going to have a date with my 4-1/2" angle grinder soon as the warranty runs out...Im going to cut the bottom bar off and make the chute opening quite a bit bigger....I bet its fine after that.Well, tomorrow I'm hauling it down to the dealer and they're going to take a look at it. Hopefully they can come up with something. He did offer me a trade-up to a Fastrak, which is another $1800, so we'll see what happens. I guess I'm not too confident they'll find anything wrong, but maybe the engine RPM's are too slow. Guess we'll find out tomorrow. Wish me luck!!!!
Yeah,,that ramp and the triangle need to go..I cant imagine how much better it would discharge without those in the way...I was thinking to bend and weld a nice piece of flat stock up and around the opening for a little more support after i do cut it,,if I still have this mower.I know my dealer wouldn't give me any crap about cutting out the corner triangle but cutting that bar off might be a different story. I'd start with the triangle and see if that's all you need. To me the only possible risk is if somebody got hurt by something coming out of that chut you might be letting the company off from any liability situation.?
So.... am I right in thinking that you're running two brand-new sds on your property?
Wow!
When you look at the airfoil around the standard blade and the airfoil on the high lift or G5 Gators you just plain old everyday know there's going to be a change. I watched my neighbor mow his lawn today with the SD I sold him a couple weeks back with Gator blades on it... it was 8 in the morning with heavy dew and he got a beautiful job.... grass and mist flying out 8 ft.
I'm not saying the raptor SD deck is a top-notch design.... but with a little thinking and adapting it can do just fine even in tough conditions. Now start saving for that fastrak....lol!
Don't spend $4,000 on a machine and demand $10,000 worth of performance from it.
Mad Mackie in CT:laughing::biggrin::smile:
Well, I also bought a set of the high lift blades for the 48" SD that we purchased at the same time. We were also having the same trouble with that one. The blades seem to have helped, but I'm also going to take that one down there and have them check the engine speed.
I'm done for now, smile, now it wasn't as painful as you thought it would be!!! HaHa!!!!
NorthernT, did you ever find anything out about your 48" unit concerning the RPMs?? Just curious.
I checked mine and it was dead on for high idle at 3600.
I was wondering, exactly how do you check the engine RPM's on these?
Randy
+1 cut the corner and the clogging goes away. QUOTE]
Info please!!! How is this done?! Thanks!
Can you PLEASE provide me with some info on this? Or maybe a link to this info? Thanks!
see this thread
http://www.lawnmowerforum.com/showthread.php/37728-hustler-raptor-sd-54-modifications
I watched a couple of ZD326 Kubotas mowing today in a large, high end neighborhood. They were mowing in damp grass with their decks set probably at their highest. Open decks, not diverters on either one and although throwing a nice pattern, they still left wind rows. I don't think the Hustler is any worse than any other brand. I may be wrong, but, those rascals aren't performing on penney's worth more than my RSD60.
I cut in the rain all the time. Sure glad I have a toro. Never any clumps or rows of grass. Oh and it cost $1000 less then the SD.
Well that might be true down there in that part of the country but up here in the northeast you will be throwin clumps with any mower when its wet,,especially if your cutting thick wet crab grass with clover and every other kind of weed...no way around that bud.I cut in the rain all the time. Sure glad I have a toro. Never any clumps or rows of grass. Oh and it cost $1000 less then the SD.
We have crab grass down here. Mostly thick blade fescue.Well that might be true down there in that part of the country but up here in the northeast you will be throwin clumps with any mower when its wet,,especially if your cutting thick wet crab grass with clover and every other kind of weed...no way around that bud.
Crab grass is the only one I really ever had any problem with but as much as I hate it the crab grass keeps me busy when things get dry cause it keeps keepin on.We have crab grass down here. Mostly thick blade fescue.
The gator blade and the removal of the triangle piece in the deck discharge opening will fix the clogging issues.
http://www.lawnmowerforum.com/showt...y-raptor-sd-54?p=212509&viewfull=1#post212509
looks like hustler updated the sd model a bit, and now calls it the sdx.
one thing they fixed is the deck discharge. time to modify mine!
video here:
https://www.youtube.com/watch?v=WC8rQM_HJ_o
Mowed the field yesterday, and it was nice and thick. Deck did not clog or get build up since I removed the triangle from the discharge chute. Very pleased with the way it throws and disperses. I wonder why Hustler has the triangle blocking the discharge? Using high lift blades, and the clippings shoot out 10 feet or so with no clumping. So for now, I won't cut off the bar across the discharge opening.
Rear tire has a leak in it. I can pump it up and mow for an hour, but by the next day the tire is completely flat. Must have picked up a nail or something. Took the rear wheel off and will fill up the kiddie pool tomorrow to find the leak and then take it to the local tire shop. Hopefully they can plug a mower tire.
Local Hustler dealer is having a free pancake breakfast tomorrow. Tempted to stop by, get breakfast and talk to them about the new SDX. Maybe even consider upgrading to the 60" Fastrak. Wonder what the trade in value is on my RSD with 30 hours. I'm sure I can't afford it!
Lovin the belt cover mod BTW
No problem bro,Its alot better than taking them all the way off cause you still get protection plus you have the cosmetic look which I really like.
Looks like you did a little welding on the baffle there..Ill have to take a pic of mine and show you guys how i cut it..I may eventually just cut it all the way back to the end of the deck like it should be.
Was thinking of this the other day and figured rather than cut the stiffening bar from the front to rear and leave it out. I may take it off, lay it flat, weld it back on and then grind the inside top of the bar down to a 45 degree angle and then if and when I run the deck into a solid object as hard as I can, it should keep the front of the deck away from the blade tip. I can't see any reason to have the bar totally gone no more clippings than it can possibly catch.
I may run it without the bar before I weld it back in if I end up doing this modification.
I started a modifications photo folder in the Hustler Turf Equipment Customer Reviews and Issues in Facebook. Anything y'all mod, shoot me a pic or a bunch of pics and I'll post them over there and give you credit for them.
Try to do before and after shots if you will.
Here is the link if anyone wants to check it out. https://www.facebook.com/HustlerZeroTurn/
Oh by the way, that page has managed to help several folks get replacement units and warranty work even though some have been outside the warranty period. So, something good coming from it.
Run by and leave a review for your Hustlers.
