Harbor Freight,Home Depot,or Lowes,,get yourself a 4" or 4-1/2" metal cut off wheel/disc depending on what size your angle grinder is..its much thinner than a grinding stone....Id say maybe 1/8" thick no more...use an angle grinder,you can get a decent one at HF for $15.I have the grinder already. Was just wondering specifically what type of wheel he used. I do use it to sharpen blades but you have to be pretty careful to not heat up the blade to much. Otherwise it works great for all sort of needs.
TurboAWD: What specifically did you use to cut the notch out on the mower deck? I will be working on mine in the relatively near future.
Thanks ........... Rhett
Yeah the cutoff wheel might and prolly will burn off the paint on the edge,,but Im not worried about that,paint is falling off my mower everyday..I gotta get some touch up...If Im going to cut the deck its going to be the whole opening,not just the little triangle.i thought about using a cutoff wheel, but was afraid the heat would burn the paint a little on the edges. so i ended up just using a sawzall with a metal cutting blade. it cut real easy.
I don't think there is enough support to cut out the whole opening. Usually mowers with full openings, have reinforcement around the top.
