Can't post pictures but, its the right side and the mower has been doing this since it was a year old (almost 3 now). The problem is where the hub and pulley mesh together. The hub spins inside the pulley wallowing out the star groves and the friction is melting the washer in the bottom of the plastic fan. Have not solved the problem as of yet but, tired of paying 81.00 or a fan assembly. Local dealer is of no use.I have the same model, and have not had any issues. Could you add more information, photos/where/left or right/ when and after how long plus what you do to solve it? I heard there was an recall or upgrade to the 3100's in the fan but not sure this applies to you?
thanks
How tight are you putting the nut on? Dealer told me this last time to run it on with an impact until its tight. Don't hold it there, but until it clicks a few times... So far I have 4 hours on the new one and everything looks good, but it took 10hrs for the last one to melt the fan.. The time before I didn't use an impact and put it on tight, but not as tight as an impact would have.I've been through over a dozen pulleys in 2 years. Finally had enough with the dealer about a month ago, the Police say I can't go back there anymore! :confused2::confused2::confused2: lol
Hi guys,How tight are you putting the nut on? Dealer told me this last time to run it on with an impact until its tight. Don't hold it there, but until it clicks a few times... So far I have 4 hours on the new one and everything looks good, but it took 10hrs for the last one to melt the fan.. The time before I didn't use an impact and put it on tight, but not as tight as an impact would have.
I can see where you are going with this option. Like you say, can't see why Hustler don't provide this as a complete single part. Don't have a welder, however will see the next door neighbour to see if he can do a couple of spot welds for me to weld the pulley and the metal piece that goes over the Transaxle spline together. Then surely it cannot wear.Bolt the pulley & fan together with cap screws then place the complete unit over the spline and do the nut up nice & tight
If you have a welder then spot of weld one the top of the pins would not go astray.
I can not see any reason why the whole shooting match could not be one piece not be one piece
