Skippydiesel
- Nov 29, 2020
- 527
Someone out there have answers for me??
Mice chewing wires. Fondle the entire harness feeling for bare or broken spots. Then continuity test from start to finish and across any and all connectors.With all fuses, key, deck clutch & relays disconnected, I have a slight electrical short - suggestions welcome.
Use a jump box AFTER the solenoid. If she cranks it will CONFORM the solenoid is bad. All the electrical heavy lifting is done by the solenoid. Should be mandatory, if you replace a starter replace the solenoid.Starter motor not working - seem likely that the solenoid is the problem.
Asian meaning Japan or the motherland China? If you want it to work get OEM. See if DB Electric has one for your machine.Should I purchase an OM starter or an Asian copy??
Is the Kawasaki (Kwaka) FX 850 V 27.hp engine a suitable replacement for the Kohler CV 745?
