Carmineb48
- Mar 30, 2014
- 8
Hello:
The motor is a Kohler serial #4121600351, model CV740S.
Last August had starting issues, thought starter, figured I save some money
and change starter myself. Still wouldn't start. Brought it to dealer, starter was good
and installed porperly, ignition switch was bad. Been running fine ever since.
Until a week ago, thought starter again, used old one I first changed out.
Cranked right over. Ran great for 1/2 a day today. PTO started to sound funny today,
thought belt may be going bad.
Today at my last 3 stops, blades wouldn't engage, i shut down mower and restarted hoping to jump
start whatever the problem may have been.
Mower would not crank again.
Got it home and was about to push it up on ramps, and it started. 3 times.
Any ideas what may be the problem? Pretty sure I have 2 good starters and ignition
switch is only 6 months old. PTO switch seems loose. Thanks for any leads/advice.
Carmine
Carmine
