Bowditchsmith
- Sep 6, 2020
- 7
Hey All,
Running into what seems like an unsolvable electrical issue for our mower.
It’s a Husqvarna YTH24K48, and it’s had a very hard previous life.
For a little bit of history, the mower was left to us by the previous owner of our house, which we were incredibly grateful for, but it didn’t come with out its flaws. I have been chasing issue after issue to try and work out the kinks.
When I acquired the mower, I knew that it burned oil on start up, it was leaking from one of the valve covers. To resolve this I did the following:
New head gaskets
Adjusted the valve timing
New valve covers
All new hard ware
All new gaskets
Oil, spark plugs, air filter, blades
The mower fired up great after this, ran much smoother and hasn’t burned / spilled a drop of oil since.
I then began to have an electrical issue. When I would engage the blade it would stall the mower out. And the only remedy was to jump the mower using a power pack. I ended up replacing the battery and the issue went away, but now 2 months later I am experiencing the same issue.
I’ve had a volt meter hooked up the to unit, and the mower is replenishing the battery, but once I shut it off, or engage the blades, the mower is dead, and needs an external power source to start back up.
I’ve included a few videos. Any thoughts on what could be killing the battery?
Model Specs:
Husqvarna YTH24K48
Kohler Courage SV725-3027
This is the mower going from a running state, turning off with the key, and trying to restart it only using the mowers battery. ( I have left a volt meter hooked up to show the surge in power loss to the battery, but as you can see in the other videos the battery takes charge once it has turned over) battery is 2 months old.
filing this video was the first time I have ever had to struggle like this to turn over, and I have never had to fight this hard to idle.
9/10 times this is how it fires up from the jump pack
New head gaskets
New valve covers
All new hard ware
All new gaskets
Model Specs:
Husqvarna YTH24K48
