Husqvarna yth21k46 safeties
Jerry4139
I own a Husqvarna yth21k46 riding lawnmower. I loaded it in the trailer but hung the deck and it hasn't started yet. The mower will not turn over, so I assume I damaged or hit a safety.
Where can I find the safety locations on the mower?
No
If you had the deck on all of the safety switches are higher than the deck
The cranking circuit goes
Battery > solenoid ( via cable ) > fuse > key switch > PTO switch > parking brake switch > solenoid trigger wire > battery ( via ground strap )
Wiring diagram is front page of the parts book
Approximate position of switches are also in pats book
parts book is a free download from Husqvarna
