My lawnmower doesn't seem like it has enough power to start. I twist the key and the flywheel might turn one complete rotation. My battery is charged. I already adjusted the valves to .005 and .007. So valve adjustment isn't the problem. I don't think. I checked the solenoid and 12.2 volts goes in and 12.2 volts goes out. But whenever I test the voltage at the starter it is roughly 2.2 volts. I took the starter off the mower and bench tested it. It seems to work just fine. Which is why i think that it having only 2.2 volts is weird. I need guidance on what to do next. I hate blowing money on stuff I am not even sure is broken.
Thanks,
Michael
Thanks,
Michael
