Husqvarna seat wires cut.
[email protected]
Some one cut the wires from the seat switch. The switch itself has 4 male connectors on it. The wires are red,green, blue, and 2 blacks. Mower will not try to start. All wires are loose and I need to connect what it takes to get mower to turn over. Any help out there?
Put up a pic of what is left, and also post the tractor's model numbers so we can look at a wiring schematic.
You can hank all the redneck blow for freedom shaved monkeys for this.
In order to stop people disconnecting the switch, Husqvarna changed it to one that has to be connected for the mower to start
