Husqvarna RPM question
3400 would be a factory spec for a lot of mower on the market. 3600 would be the max allowable from the engine manufacturer, but do to pulley configurations 3400+/-150 would be within the normal range for turning the hydro pumps within their designed spec as well as keeping the blades below the 19000 fpm rating set by Ansi.
ILENGINE, thank you so much for your reply with good news. The mower is running good, I should not look into it.
To say you have s FR691V does not give the information needed to get the top no load RPM's of the engine. Spec no. is needed.
