I need a diagram for the LTH120 riding mower deck installation that specifically shows where the parts are connected to. On this deck it is a mystery as where the Deck clutch cable with spring from the engage/disengage cable from the panel. I've looked at the parts diagrams and they don't show anything but the parts. I 've contacted Husqvarna, and they were no help whatsoever. There is also a smaller spring that is on the deck and that is a mystery also. If a detailed diagram is available it would be appreciated if you would share.
Thank you
KER
Thank you
KER
