HUSQVARNA LTH120 WITH 38 INCH MOWER DECK DIAGRAM
KER
I need a diagram for the LTH120 riding mower deck installation that specifically shows where the parts are connected to. On this deck it is a mystery as where the Deck clutch cable with spring from the engage/disengage cable from the panel. I've looked at the parts diagrams and they don't show anything but the parts. I 've contacted Husqvarna, and they were no help whatsoever. There is also a smaller spring that is on the deck and that is a mystery also. If a detailed diagram is available it would be appreciated if you would share.
Thank you
KER
Fish
Put up the numbers off of the tag under your seat, and we may be able to help.
KER
Ok here are the numbers from under the seat as follows , MODEL LTH120 SN # 120399C001480 MFG # 954140106A PRODUCT # 954-14-01-06
KER
For those of you that have Husqvarna outdoor power equipment, I would not get anymore.:mad: I did come across the repair information that I needed.:wink:
Thank you for those who responded to my thread.
KER
