Husqvarna LT112 briggs&stratton 12hp won´t start
shefki
Any advise where to start investigating this?
Battery is fine and it tries to ignite when starting.
Here is the video from unsuccessful startup try.
EightWide
As a kid with a kickstart 3/4 hp Briggs that wouldn't, I'm asking , what can it be? " This Old timer said "Son, if you got good compression, good gas, and good spark at the right time, It's gotta run. Still true. Just more things to interfere now.
Eightwide.
Google will not let me look at the video unless I sign up for all sorts of spy wear that I have no intention of doing.
If I wanted the world to know what size undies I wear & when I take poo I would be on Feaces Book and use an android phone
shefki
Sorry for your troubles. Video sharing should work now.
This is just a kind request to get some help on the issue and how to start investigating it. Give a reply if you want to help.
I can hear what sounds like blades spinning when the engine is cranking
If the PTO is on and the engine cranks then there is a big problem with the electrics.
OTOH if the rattle & rumble is the flywheel spinning loose on the crankshaft then the fix is to replace the timing key & proper;ly tighten the flywheel down
So start by removing the blower housing and see if the flywheel is spinning the engine or just spinning loose on the crankshaft
If it looks OK then remove the kill wire to the coil and crank the engine
If you get no spark then the coil is Stuffed
If you get a spark the coil is OK
It also seems to be spinning too fast like the plug is out or the cam shaft is broken.
But do the first few test & get back to us.
Time for me to hit the farter but some of your countrymen should be awake long enough to work out what is happening if you do the tests & post the results.
Fish
Yeah, no compression.
If you do fix it, tighten the engine mounting bolts as well.
shefki
Thanks for your kindly help, much appreciated! I will do as advised and start identifying the root cause.
I´ll keep you updated.
keakar
that thing is spinning free with zero compression as though the piston rod has broken or something
to be honest i wouldnt waste time on it and just buy an old craftsman or murray riding mower and use the 15-16hp engines that come on them as an upgrade replacement. you can buy old mowers with running engines that have bad decks on them for $50-$100 all the time
Scrubcadet10
Moderator
Staff member
I would remove the spark plug and get a pencil or small object that will fit in the plug hole, rotate the engine by hand, or have someone just bump the starter and see if the piston is moving, or you could also just remove the spark plug and place your finger over the plug hole to feel if there is any air being displaced by piston movement.
shefki
Thank you all for helping with this issue . I found the reason after removing the engine cover, unfortunately there is a hole in the engine block..
So I think this is the end of the story then or does someone engourage still to fix this thing?
