Husqvarna LGT2654 - Model 960450047 (2016)
dennis@osceola
I am looking for the correct mandrel assembly number for this model number. The repair parts catalog shows the numbers for the individual components (housing, spindel, bearing, etc), but I am having issues finding the assembly number to order. I believe the current mandrel assembly number is 587819701, which I believe replaces 532192870. During the process of ordering, it asks to verify the correct part by entering the model, which I did. However, it cannot locate the model number. Could someone please advise?
Yes the new mandrel number is 587819701.
I believe it changed when they sourced them in China because the new housing is 30% cheaper than the original which was made in the USA
Thanks, I appreciate the quick response. Now all I need do is source which supplier provides all the hardware that should accompany the mandrel assembly :) . Again, thank you.
It should come with the top & bottom spindle bolts and beware it could be metric.
All the ones I buy come with them ( Stens , Rotary & Prime Line )
All of the above companies also sell the acorn bolts used to mount the housing.
The housing is not threaded & I usually prethread it using an old mounting bolt
