Husqvarna EZ4824 No start
Thank you both! How can I check the voltage at full throttle if I am off of the seat? How do I bypass that seat switch?? Just unplug it?? I am heading to the barn to follow your directions today! I appreciate your help. Ok, I checked voltage at full throttle and got 14.10V. The PTO switch appears ok still. I get continuity on two blades when closed and two dfferent blades when closed.
Ok. so I replaced the PTO switch with a new one and still nothing. I found a set of two green wires going down to what I think is the electric pto unit. This does not seem to be a plug in situation, it seems these wires feed directly into the unit.
There are two plugs leading to this unit. I put 12V to the plug closest to the unit and nothing.
