Husqvarna/Craftsman AWD Blade adapter quandry
dberry1052
All wheel drive craftsman (husqvarna)..... The blade adapter problems. Replaced it with correct part number, but when it's installed all the way in on the shaft, the pulley portion does not align with the three tension pulleys so that belt will be on the same plane. The belt would likely throw.
It looks to me that there should be a spacer between the shaft and the Adapter, but parts breakdown down not show this. The new adapter only has about a inch long Key built in to align with the key slot on the shaft. If i did use a spacer, there would not be enough key/slot engaged to keep it from breaking off (i've had two do that) am I ordering the wrong adapter? I looked up the part number in Sears direct and its the same part as the Husqvarna mower AWD models.
This is weird because the original adapter did not do this. I replaced because the owner had hit something with the blade and erased the blade retaining "flower" on the end of the blade adapter.
Am i going mad or what?
Apparently something not right here. When I look at the image of the part online there is no bushing but but your image it definitely looks like the should something.
Try comparing the old part to the new part. Maybe you can see the difference.
Sorry that I can't be of much help here but I simply just don't walk behinds here. Years ago I did but not now.
I just replaced one of those. The first aftermarket one didn't tighten down properly and the belt didn't line up. The complete end of it broke off after 5 mins of running. That was fun. OEM one worked. Cust supplied the AM one.
While you are in there remove the idlers and pop a seal off and oil the bearings.
