I have a Husqvarna with a Briggs and Stratton engine. It had a few problems like the start cable was broken (fixed). Then noticed it was leaking gas, so had the gasket changed and it no longer leaks.
The problem is it starts, then putter outs almost immediately or after a minute, or then it will run sometimes for 20-30 minutes (it seems) pretty good. Then dies out. Then when you try to start it, it starts doing the same things.
I thought then it might be the gas, then drained it and tried new gas, then tried a little heat thinking there was water though tried a few different gas containers.
Also chained the spark plug and filter. Tried it with the filter off, oil seems ok. I thought it might be air causing the trouble, he said there isn't an adjustment to allow more gas. I can't see on the carburetor 9p702-0010-F1 where there could be an adjustment? But when it is running, seems to work well? Any suggestions or thoughts. It starts usually one pull. Thanks Bruce
