trooper1954
- May 29, 2012
- 194
Hi,
I have an older trimmer that has a priming bulb. After lots of primes it will not start, until I put a few drops of gas into the cylinder. When I pull the plug it looks light grey....I suspect that the priming bulb is not priming because of an air leak....I think around the grommet that goes into the tank.
Would this cause these symptoms?
Thank you.
Thank you.
