irish1two3
- May 3, 2014
- Threads
- 1
- 8
Bad solenoid since you have 12V+ on the white wire, should have had 12+V on solenoid starter side when cranking.
Turned out to be a problem with the ground to the solenoid. I grounded it to the chassis and it works with the key now. Very frustrating but thanks for all the help
