Husqvarna 2348 won't crank using the key
irish1two3
Bad solenoid since you have 12V+ on the white wire, should have had 12+V on solenoid starter side when cranking.
Turned out to be a problem with the ground to the solenoid. I grounded it to the chassis and it works with the key now. Very frustrating but thanks for all the help
Mikel1
Glad you got it. So is the hour meter now working?
irish1two3
No, but it's probably related to the ground issue. Going to dig into that this weekend. Thanks again.
