Hmm, sounds familiar, only my YTH21K46 that I purchased this past May came from the dealer like that, I am pretty sure. More comments follow pic. Note how the right wheel is turned out, though the steering wheel was turned straight. The left front wheel is straight, but running like this veered the mower to the right.
I remembered noticing when I first brought it home that to go straight, the steering wheel was about a quarter turn off, and, while disappointed was not all that critical about it.
After mowing with it a couple or three times, I really began to notice how it was hard to go straight, and to go straight, I had to hold the wheel where both tires were bowed out.
I jacked up the front and noticed the plate bracket thing that attaches the tie rod to the left front wheel was bent. More comments follow the pic below.
Since under warranty, I decided to return to dealer instead of attempting to repair myself. I honestly could not remember doing anything to mess it up, but did confess that it does venture across some challenging terrain sometimes. I would not have pushed it in the least had I not remembered the thing about the steering wheel from the first day.
They fixed it under warranty. I don't know and don't really care whether they pulled it and bent it straight or replaced, but am satisfied they fixed it at no expense to me. Sometimes these things get rough treatment in their shipping crates, loading, traveling, docking at freight terminal, reloading, shipping, or wherever. I think it got jolted somewhere in that process.
I purchased this unit a couple of years ago and it has worked pretty well. I am lucky that my wife does all of the mowing. Recently, when she was bringing the mower back to the house, I noticed the front wheels had a significant toe-out. There didn't seem to be any adjustments and I have jury-rigged one of the tie rods to bring it close to alignment. It appears that the front axles is bent back towards the mower deck. This throws out the alignment and puts the wheels very close to the mower deck. What I really noticed was not the alignment but that the front tires were almost worn out and for a mower this new, that didn't make sense. When I look at things, I don't see anything bent, but it must be.
What is the recommendation about how to straighten out the front axle assembly? There isn't much to connect to to bend... and I would like to try to prevent it from reoccurring.
Any assistance would be greatly appreciated.
The only other issue I have had is that on occasion, when it starts up, it smokes quite a bit.... after it warms up, it clears up... but it doesn't do it all of the time. When I purchased it, they pointed out the Vanguard engine and said it was much better than their standard engine, but I'm not convinced....
Thanks in advance for any help!
Bill in Vancouver, Wa.
