Husq YTA24v48 (hydrostatic trans) loses all traction on hills & rolls uncontrollably. When it stops the tractor won't move when pressing forward or reverse pedal. After a couple of hours, it will go forward or reverse on flat terrain but will lose traction again on hills. Motion drive belt look OK & seems tight when inspected after losing traction. Pulleys looks OK too,. Any ideas? Thanks.
I have a YTH24v48, that I bought in 2017.  Sometime in the past couple of years, Husq changed the model to YTA, as a result of the swap to a different transmission.  I've seen reports about the YTA not working very well on steep inclines.
				Husqvarna YTA24V48 review to help you make the best purchase. Ultimate guide to see all the features, pros and cons at a glance. Updated [current_month_year]!
					www.toolsofficial.com
You should inspect the belt area...and perhaps even replace the belt, to be sure....and look for Any buildup of debris, or any evidence of pulley wear, then contact Husqvarna, and let them know your problems.  The YTA should have a 3 year warranty, so there is a pretty good chance that your mower is still under warranty.  You can find the model/ser.#, and the Husqvarna phone number on a label under the seat.  If your unit is still under warranty, the sooner you contact Husq, the better.  A new transmission is expensive.
