This just started. It starts fine, idles fine, and I can even engage the blades when the brake is pressed. As soon as I release the brake, the engine sputters and dies.
Sounds like a fuel system issue, Would help if you posted the engine model,type,code numbers, I suspect you have a Briggs 24HP..?? the info we need is stamped into one of the valve covers (see example)
.......... click to enlarge
Usually the carburetor is dirty, which requires removal & THOROUGH cleaning, possibly a rebuild kit, also it would be of great benefit to THOROUGHLY clean the ENTIRE fuel system, the gas tank, shut-off valve and replace the filter and fuel lines, no sense cleaning the carb then re-introducing dirty fuel into it, we have the info to walk you through it, BUT as I stated, we need to know for sure, what exactly were working with, we await your info, ( pics of carb would be very helpful ) .. :thumbsup:
Are you engaging the blades at FULL throttle ..?? Will the machine "roll freely" in Neutral .. ?? does it have ELECTRIC PTO ..?? ( blade-engagement ) .......??
IF he can apply a big load like engaging the blades without problems then it suggests the brake switch.
A faulty seat switch would not allow the blades to spin.
That is correct on the loading of the engine,,,, That's why I thought of you correcting me on that diagnosis I made 6 months or so ago..... If it was the same issue.....
When the blades are engaged it puts the load on the engine while the brake is still pressed so that eliminates the fuel and 1 cylinder issue........ So it's gonna be a bad switch or a bad connection at the brake............ Seemingly that's the best guess in theory..... But can a faulty or bad connection at the seat switch not think what the brake switch is thinking ??
All the different N/O and N/Closed switches are a PITA nowadays.........
In my opinion I think there should be only 1 switch on the mowers... The seat switch... When you get off it kills the whole shebang and if someone is STUPID enough to by pass that then it's on their own accord if they get hurt.......
