Starting with starting fluid is not necessarily a sign of spark. The fluid acts as a accelerant and even the weakest spark will ignight it.
Just pull the plug reconnect the disconnect plug to the boot hold the end of the plug (the spark side) to the engine block and turn the engine and see if you have spark
I put the new plug in and pulled the cord but still no start. The serial is: MZCG 6183521 with a ZG at the far right.
