Hi, I have a Honda HRT216SDA mower that's served me well over the years. It recently cut out on me and wouldn't start. I squirted some starting fluid into the engine through the carb and it started right up, so I figured it must be the carb. I took the carb apart and cleaned it, reassembled, still no go. I then bought a new carb since they're only about $20 on ebay, but after attaching it, it still won't start. Fuel is flowing from tank to carb fine, it just doesn't seem to be getting from carb to engine. Any thoughts? Thanks
Are you getting spark? Do a spark check first, as it may just need a spark plug.
If you are getting spark, was the replacement carb you installed genuine Honda, or some aftermarket company?
Did you get all the gaskets and guide plates installed properly?
Share your serial number with me and I can get you more service information:
Robert,
I have the same model Honda lawn mower as motaro38 and have a problem with a spark plug so perhaps you can enlighten me:
Need that serial number off the back of the mower deck to get you the correct service info...I also need it to confirm that is the correct part number for a replacement carburetor.
Hi Robert,
Sorry, turns out it is a different Model: HRT 2162TDA, Serial No: MZCG-6971007.
Thanks!
The part number of the carb you bought on eBay is indeed for Honda GCV160 engine, but it is not the right one for your mower. Not saying that is what the issue may be, but you really should get the correct carb installed first. The correct Part Number is 16100-Z0L-023, list price is $15.08.
Google the part number to find a Honda Dealer selling it online, or use this link to find a Honda Dealer in your area:
Find A Honda Dealer
With the correct carb installed, do a spark test first, and confirm you are getting good spark.
Drain ALL the fuel from the tank and fill with fresh 86 octane regular unleaded.
Next, make sure the choke is working properly; it should fully close the choke butterfly when engaged, and fully open when the throttle is moved to FAST.
Check the air cleaner element for rips, tears or excessive dirt, clippings, debris.
Confirm all the gaskets and spacers are correctly installed with the carb, and all spring, linkage etc. are also correct.
Make sure the two long bolts that hold the carb, choke and air cleaner are secure (vacuum leak can cause surging).
Thanks for your response Robert. Sorry for this beginner question, but how does one go about doing a spark test?
Share your serial number with me and I can get you more service informatio:
Starting with starting fluid is not necessarily a sign of spark. The fluid acts as a accelerant and even the weakest spark will ignight it.
Just pull the plug reconnect the disconnect plug to the boot hold the end of the plug (the spark side) to the engine block and turn the engine and see if you have spark
I put the new plug in and pulled the cord but still no start. The serial is: MZCG 6183521 with a ZG at the far right.
Yep, nice strong bright spark:Okay, so did you do a spark test? Can you confirm you are getting spark?
It wasn't that old when it stopped workingNext, how old is the gasoline in the tank? Any fuel over 45 days old should be drained out of the tank and carburetor and refill the tank with fresh fuel.
Yeah it does, tried starting it in both positions no go. Could smell gas too and float bowl is full so its gettin into carb just not to engine.Check the choke plate and make sure it is fully closed when the throttle lever is set to CHOKE. You'll need to remove the air cleaner cover and filter element to see the choke plate. Move the throttle to SLOW and confirm the choke plate opens up all the way.
How about some photos? Would like to see close-up of the carb, choke, linkage etc.
I mighta messed that up, I'll reassemble like yours and try again.
Hopefully, that is all it is. Please let us know the outcome.
Also what is this tube for?
There is a filter screen inside the fuel tank where the fuel line connects. Make sure that screen is totally clear.
The small screen is inside the tank next to the rear wall about midway. Find where the fuel line connects to the fuel tank. Now look down inside the tank with a flashlight and the brass colored screen is visible on the bottom of the tank right above the fuel tank outlet. I remove all of the fuel and fuel line and spray carb cleaner on the screen to clean it. Once in awhile I remove the fuel tank, dump the fuel and use Dawn dishwashing liquid and hot water to clean the inside of the tank and screen. I then use compressed air to blow out the tank and screen and let it completely dry in the sun before re-installing. I would suggest you add an in-line fuel filter between the fuel tank and fuel shut off valve. Very easy to do and it helps keep the carb clean.
I unscrewed the nut on the bottom of the carb and fuel came out so fuel is definitely getting to the carb.
Thanks firedawg I'll do all that. Could you explain to me how the fuel is "pushed" from carb into the engine with these engines? Could there be something clogged there?
especially the air guide and the insulator. Failure to do causing "surging" also known as "hunting".
The air guide being the thick plastic washer type thing that goes between the carb and the engine? Has the little carved out pathway/tunnel in it?
If you are getting a good flow of fuel from the tank to the carb and have good spark I would next look to see if your intake or exhaust valve is stuck. A stuck valve is a pretty common problem due to varnish on the valve stems from ethanol in the fuel. These engines can usually be freed up relatively easy.
Ok, can you give me a brief explanation on how to do this? Thanks
Way over complicated.. take the valve cover off and pull the cord you can easily see the valves moving. If they are not it is stuck. Make sure engine is off and push on the valve that is Stuck until its moving pull cord it should be moving. Throw some 2 cycle oil in gas a very very small amount and that'll lube it up
Probably not if your careful taking it off the gasket should be fine... I have never had to replace or use a sealer with a lawn mower valve cover
What a pain replacing the carb is though, lining up all the holes in all the parts to get to the engine.
On a side note, I often have to tune the high and low speed needles on my 2 stroke engine carbs. Do lawn mower carbs(specifically this Honda carb) ever have to be tuned? Thanks
Instead of the gaskets, any of you guys ever try using just permatex gasket maker instead?
