upupandaway
- Jul 3, 2015
- 36
- 631
Your top red arrow is correct- that is the level that leads to close the choke. Try it yourself and push that up and see if the choke closes. If it doesn't close, bend it down a little bit and check again. If ok, then try the throttle and see again.
With your picture, it is currently not pushed forward(thus pushing the choke) all the way yet. If the throttle is already all the way forward, maybe slipped forward in the clamp at the end of the cable's black jacket(it looks like it didn't, but....).
The throttle cable itself doesn't look like it slipped so the choke should be closing when u push the throttle all the way forward to choke but then again, loosen the screw and pull the throttle cable to the right(in your picture) a little bit and see if that resolves your problem...
I have seen where the "horizontal part" did wear a notch in it so that would also reduce it from moving far enough.
Yours doesn't look like it is worn but now u know what it is *supposed* to be doing.
It looks like all the parts are ok so it shouldn't take much adjustment to get it to work properly.
