chevyman142000
Hello - I picked up a Honda HRN 216 mower off Facebook marketplace for $20. The person said the engine had issues, but they weren't sure what was wrong. Basically it was hard to pull. I put it back together, they had the motor off of the deck. I was able to get it to run for close to a minute, and then it died. I took the spark plug out and it is still hard to pull. I checked the flywheel brake and that is definitely disengaging properly. Other weird thing is I think it got hard to pull after it ran the one time. Wondering if anyone has had a similar issue with this engine? I haven't flipped it over to check and see if the shaft is bent or not yet. By the way, the blade and the drive belt are removed. Let me know if I can provide any other details. Thanks in advance for any help and advice.
