How to set valve on a 17hp kohler cammand engine
slyme
I have a craftsman rider,917.273140, with a 17hp kohler command engine that I wanted to adjust the valve on but when I took off the valve cover I realized these valves are different then the ones on briggs engine.
Thanks in advance for any help.
You will find some of the Kohler command engines have nonadjustable valves. They use hydraulic style lifters. I don't know what you have?
