S slyme Member Joined Sep 30, 2015 Messages 10 Oct 28, 2015 #1 I have a craftsman rider,917.273140, with a 17hp kohler command engine that I wanted to adjust the valve on but when I took off the valve cover I realized these valves are different then the ones on briggs engine. Thanks in advance for any help.
reynoldston Lawn Pro Joined May 23, 2011 Messages 5,705 Oct 28, 2015 #2 You will find some of the Kohler command engines have nonadjustable valves. They use hydraulic style lifters. I don't know what you have?
R Rivets Lawn Royalty Community Leader Joined Mar 11, 2012 Messages 16,285 Oct 28, 2015 #3 Section 11 of this manual should answer your questions. http://www.kohlerengines.com/onlinecatalog/pdf/tp_2339_d.pdf
