How to remove oil plug on Craftsman 30in. 6speed riding mower
jimvt
  • / How to remove oil plug on Craftsman 30in. 6speed riding mower
I need to change oil in this unit and I can't for the life of me determine how to remove
the oil sump plug.
It's the nut(?) at the bottom of the sump.
3/8 Drive extension should fit the square hole to remove the drain plug. when you get the plug out it would be a good idea to screw a short piece of pipe in there with a cap on the end, to prevent oil from going all over the mower on the next oil change.
Carscw
And remember to change the oil with the engine warm.
(( racing is the only sport that you need two balls ))
jimvt
Sorry...3/8 drive extension of what?
Carscw
A 3/8 drive ratchet ( the thing you put a socket on)
The extension for use on a 3/8 ratchet wrench. the square end fits the square hole in the drain plug.
jimvt
Thanks, my friend....it was a 1/4 incher that did it.
Sears gave no clue in the manual as to how to do it.
TNX
