gregjo1948
- Nov 28, 2012
- Threads
- 79
- 393
Ferris ISZ KAV 23/61 serial 2495 How can I check for and /or remove air from my hydraulic system? I bought this mower with a bad motor and have installed a new one. I installed new hydraulic filters without filling them with fluid first. The machine moves forward poorly and barely moves backwards on a level garage floor. I've adjusted the linkage which was almost dead on. I'm thinking that air in the system might be my problem. Is it a self bleeder or a way to manually bleed the air out? I can't believe both pumps would die at the same time.Thank you for any help you may render. gregjo1948
