bluefitness
I don't want to put too much into this old lawn mower. The threads stripped in one of the bolt holes for the intake. I don't have a tap and die set, but I can try to purchase one from Harbor Freight. I also read about Heli coil inserts. What is the least expensive way to repair this? Do you think it will hold if I just use RTV gasket and use a single bolt?
