I just bought an older Yard-Man garden tractor and I didn't get any doc with it. I found the model and serial # on the tag under the seat but I suspect it may not be the original seat. The reason I suspect that is because I own a Yard-Machines garden tractor that I have doc for and both seats have the exact same model/serial number which is 13BQ695H352 - 1C028H30215. When I try to find doc based on that model/serial even if I specify Yard-Man all I can find is doc for the Yard-Machines. The Yard-Machines has Hydrostatic trans, 46" deck and standard steer. The Yard-Man is 7 speed trans, 42" deck and is 4-wheel steer. Can anyone help me find the model/serial and/or documentation?
I want to read up on how to replace the drive belt and maybe other parts there abouts. It won't go up much of any incline. It just slips in about every gear. It's a little better in 3rd but not much. Does that sound like slipping drive belt? Maybe it needs a new tensioner spring?
