wilburn cox
 - Feb 24, 2014
- Threads
 - 40
 - 107
I posted on 9/12/2018 about a weird noise at start up on my Murray mower. As i stated in the post the motor runs fine after starting. I am wondering if there is a bad connection somewhere between the battery, solenoid or a ground. How can I check the voltage getting to the starter? I have a multi meter and necessary tools.
Any assistance will be appreciated. Again I am asking if there may be a voltage drop some where between the initial turning of the ignition key and the current to the starter. I may be way off on my thinking but after applying dry lubricant to the spiral I still have the same noise.
Thanks in advance
Wilburn "Red" Cox
Thanks in advance
Wilburn "Red" Cox
