Typically how much throttle should you give the D110 when you are mowing? I usually try and keep the throttle at about 25%, or about 1/4 of the way up on the lever.
And does it hurt it to mow for an hour straight with the throttle set higher? I had one person tell me its actually better for this engine to run a little faster as compared to a little slower.
Mike
Mike
