How complete is the Briggs repair manual?
Jay1947
Hello all, I am working on my daughters JD 135. It has a 22HP vert shaft Briggs. Took the carb off to clean. Found two jets on the work bench after spraying carb out. Do you know if the Briggs manual is detailed enough to show the orientation of these jets? I think they go in the bottom right above the float bowl but not sure. And not sure of the up/down orientation. Any help will be appreciated...........Jay
No the briggs manual assumes you have been to the Briggs training school and are a trained mechanic.
If there is a step in the outside of the jet, the smaller diameter goes in first
If the hole has a chamfer then that will go on the float bowl side ( fuel passes in there first )
If this is a double barrel carb, the jets might be different sizes.
We need the full engine number to give you specific advice.
Model, code & serial because carbs & jets change very regularly
This site is aimed at the handyman ( sexist bugger ain't I ) level.
http://outdoorpowerinfo.com/repairs/briggs_intek_v-twin_carb.asp
Jay1947
OK Thank You Will go to that other site But:
On right valve cover
Model 407777
Type 0232 B1
Code 090526YG
And on flywheel shroud
GXA135A300748
This is a Lowes mower not a real John Deere also. Thanks for the help..............Jay
Jay1947
Thanks to that other site I think its OK. One problem, I lost the tiny nylon bushing the governor rod goes through. Any ideas where I can get some?? Thanks..............Jay
