Thanks. (edit) 725cc 20hp to 25 hp.Probably a different jetted carb, as manufacturers can only advertise engine hp as appropriate. Today’s engines are designated by cylinder size. Changing jet size will change horse power.
We use to refer to it as the $130 screw because that was the price difference between the CH18 and CH20. But if you removed the screw on the CH18 you voided the warranty.Good answer. Even a lot of seasoned Kohler techs don’t know that info.
I wouldn’t have denied warranty if that screw were missing.But if you removed the screw on the CH18 you voided the warranty.
You wouldn't had to make that decision. The Kohler distributor rep that had to sign off on the replacement short block or engine replacement would of had the final say.I wouldn’t have denied warranty if that screw were missing.
